Flowcode Help Overview
<sidebar>Sidebar: Flowcode Help Overview</sidebar>
A set of videos are available showing some projects using Flowcode as well as talking you through some example programs. Flowcode video playlist
Version 7
- New in Flowcode 7 - Introduction to new features in Flowcode 7 and other useful information
 - Chips - List of supported microcontroller devices in Flowcode
 - Migrating to Flowcode 7 - Help and advise moving to v7 from an older version
Getting Started
- Activating_Flowcode - Activating your Flowcode license
 - Opening_Flowcode - Launching the Flowcode application
 - Finding_Your_Way_Around_Flowcode - Finding your way around
 - Creating_Flowcharts - Creating your first Flowcode flowchart and see the options available
 - Selecting_a_Target_Chip - Selecting the target microcontroller device
 - Configuring_the_Chip - Configuring your device
 - Opening_an_Existing_Flowchart - Opening an existing .FCFX Flowcode project file
 - Selecting_a_Template - Opening a template project file
 - Saving_a_Flowchart - Saving your program
 - Creating_Templates - Creating your own templates
 - Closing_Flowcode - Closing Flowcode
 - Disabling the 3D Panel - Disabling the 3D interface
Flowcharts
- Icon_Properties - Flowchart icons and their functionality
 - Adding_an_Icon_to_a_Flowchart - Adding flowchart icons to your program
 - Editing_Icon_Properties - Editing the properties of a flowchart icon
 - Adding_Comments_to_a_Flowchart - Commenting your flowchart
 - Selecting_Icons - Selecting icons on the flowchart
 - Flowchart_Editing_Functions - Functions to make editing your flowchart easier
 - Printing_Flowcharts - Printing out a flowchart
Macros
- Creating_a_New_Macro - Creating a new flowchart macro or subroutine
 - Editing_and_Deleting_Macros - Editing a macro and removing a macro from your program
 - Using_the_Project_Explorer - Features of the project explorer designed to help simplify programming
 - Exporting_a_Macro - Exporting a macro from within Flowcode
 - Importing_a_Macro - Importing a macro into Flowcode
Functions
- Mathematical_Functions - Built in routines designed to help with mathematical operations such as Sin() and Float
 - String_Manipulation_Functions - Built in routines designed to help with string manipulation
 - Undo_and_Redo - Undo and Redo operations and shortcuts
 - Disabling_Icons - Disabling flowchart icons to comment out sections of code
 - Icon_Annotations - Icon annotations
 - Find_and_Replace - Ability to search within your flowcode project to replace specific text with alternate text
Variables
- Creating_Variables - How to create a variable
 - Variable_Types - Variable types and their meanings
 - Editing_Variables - How to edit a variable
 - Variable_Manager - The Flowcode variable manager interface
 - FiniteStateMachine - Programming tutorial on using state machines
Panels
- Panels_Where_And_Why - What the panels do and how they help you design your system
 - Choosing_your_Simulation_Panel - Information about choosing the correct panel
 - Dashboard_Panel - More in depth information on the dashboard panel
 - System_Panel - More in depth information on the system panel
 - Zooming_the_View - Zooming in and out on panels
 - Camera_Control - Controlling the camera looking at the panel
 - Object_Position - Object positioning on the panels
 - Local_and_World_Space - Local vs World space regarding coordinates
 - Object_Scale - Objects and their scale
 - Object_Rotation - Rotating objects
 - Working_With_Meshes - Using meshes inside Flowcode
Tools and Views
- Tools_and_Views - Various tools and views available inside Flowcode
 - Using_the_Data_Console - How to use the data console window in your programs
 - Using_the_Data_Scope - How to use the data scope window in your programs
 - Using_the_Icon_Lists_Pane - The icon lists pane
 - Project_Options - Detailed help on the Project Options window
 - Global_Options - Detailed help on the Global Options window
 - Chip_View - The chip view window
 - Analog_Window - The analogue inputs window
 - Properties_Panel - The properties panel
 - Simulation_Debugger - The simulation debugger window
 - Component_Debugger - The component debugger window
 - Supplementary_Code - Supplementary code and its usage
 - Saving_Images_in_Flowcode - Creating images of your flowchart source
 - Auto_Documentation - Auto documentation features to speed up development
 - Window_Layouts - The window layouts manager
Components
- Component - Information about what a component is and how they work inside the Flowcode environment.
 - Common_Components - Information on some of the more commonly used components
 - What_Is_a_Switch? - Detailed information regarding the switch components
 - What_Is_an_LED? - Detailed information regarding the LED components
 - What_Is_an_LCD? - Detailed information regarding the LCD components
 - What_Is_a_7_Segment_Display? - Detailed information regarding the 7Seg components
 - What_Is_a_Keypad? - Detailed information regarding the keypad components
 - Selecting_Component_Macros - Information on how to use component macros
 - Component_Help_Files - How to get access to component help via Flowcode
 - Component_Properties - Information on how to use component properties
 - Component_Tree - Information regarding the component tree hierarchy
 - Replacing_a_Component - Replacing one component with another
 - CAL_Components - Overview of code abstraction layer components
 - Using_the_Data_Injector - Data injectors and communications components
 - Component_Directories - Information on creating your own components directories
 - Editing_Key_Mappings - Assigning keyboard presses to functionality during simulation
 - Remappable_Peripheral_Pins - Assigning pins to peripherals on devices with re-mappable functionality.
Component Creation
- Creating_a_Property - How to create a property
 - Panel_Managers - Overview of the component creation panel managers
 - Number_Conversions - Creating a helper component to help convert between number systems Decimal, Hexadecimal and Binary
 - Assigning_Code_to_an_Existing_Component - Complementing or overriding an existing components functionality
 - Base_Components - The base components and their function
 - Using_A_Base_Component - Creating a new component using a base
 - Creating a two wheeled robot - Creating a 2 wheeled robot from scratch (simulation & downloadable)
- Starting_Flowchart_Simulation - Information on how to use the flowchart simulation
 - Simulating_Icons_Step_by_Step - Stepping through icons
 - Breakpoints - Using breakpoints
 - Bookmarks - Using bookmarks
 - Changing_the_Speed_of_a_Simulation - Changing the run speed of the simulator
 - Simulation_Only_Code - Code designed to work only via the simulator
 - Simulation_Events - Event macros used to provide more functionality to both simulation and compiled code
 - DLL_Support - Changing the nature of a macro to instead call a external DLL function (simulation only)
 - Data_Scope_Test - Information on how to use the Flowcode data scope window.
 - CodeProfiling - Introduction to Code Profiling, and how to use it
Chip Specifics
- Compiling_a_Flowchart_to_a_Chip - Information on how to compile a flowchart into machine code
 - Internal_Oscillator - Specifics on using an internal oscillator
 - Phase_Locked_Loop_(PLL) - Specifics on using a PLL frequency multiplier
 - Custom_Interrupts - Custom interrupts for your hardware
 - Debugging_Hardware_and_Software - Tips on how to debug hardware and software
 - In_Circuit_Debugging - Overview of the in circuit debugging (ICD) interface
 - In_Circuit_Test - Overview of the in circuit test (ICT) interface
 - Supporting_Third_Party_Programming_Tools - Using 3rd party programmers such as PICkit and Arduino
 - Viewing_Code_Output - Viewing the code generated by Flowcode
 - Managing_Compiler_Options - Overview of the compiler options settings
 - FCD_Data_Collection - Chip definition files and how to collect data from them
Support
- Frequently_Asked_Questions - Frequently asked questions
 - Reporting_a_Bug - How to report a bug in Flowcode
 - Licensed_Compiler - Compiler specifics and license agreement
 - Technical_Support - Information on how to get further support
