Components
Revision as of 15:18, 12 November 2013 by JonnyW (talk | contribs) (XML import of only descriptive example files)
MIAC Module
Image MIAC TODO: Examples,SimMacros
Image MIAC USB Slave
Controls
Image Dashboard Text TODO: Examples,Properties
Image Panel Console Viewer TODO: Examples,Properties
Image Scale Arc TODO: Examples
Image Scale_Linear TODO: Examples
Image Simulation LED TODO: Examples,Properties
Image Slider control TODO: Examples,SimMacros
Image Texture scroll TODO: Examples
Comms
Image CAN TODO: Examples,DLMacros,SimMacros,Properties
Image FTDI FTD2XX TODO: Examples
Image I2C Master TODO: Examples,Properties
Image LIN Master TODO: Examples,Properties
Image LIN Slave TODO: Examples,Properties
Image MIDI TODO: Examples,DLMacros,Properties
Image Modbus Master
Image One Wire TODO: Examples,DLMacros,Properties
Image RS232 TODO: Examples,Properties
Image SPI Legacy TODO: Examples,DLMacros,Properties
Image TCP Base TODO: Examples,Properties
Image USB HID TODO: Examples,Properties
Image USB Serial TODO: Examples
Image USB Slave TODO: Examples,Properties
Image Visi Interface 4DSystems TODO: Examples
Image Webserver EB023_00_1 TODO: Examples,DLMacros,Properties
Image Webserver EB023_00_2 TODO: Examples,DLMacros,Properties
Wireless
Image Bluetooth TODO: Examples,Properties
Image GPS TODO: Examples,Properties
Image GSM TODO: Examples,DLMacros,Properties
Image IrDA TODO: Examples,DLMacros,Properties
Image RC5 TODO: Examples,DLMacros,Properties
Image RF ISM TODO: Examples,Properties
Image RFID TODO: Examples,DLMacros,Properties
Image WLAN TODO: Examples,Properties
Image Zigbee TODO: Examples,DLMacros,Properties
Advanced
Image Button helper TODO: Examples,Properties
Image COM Port TODO: Examples
Image Circular Buffer
Image Clone Matrix TODO: Examples
Image E_block Helper
Image FCD helper TODO: Desc,Examples
Image Marking control TODO: Examples,SimMacros
Image Motion Helper TODO: Examples
Image Port Matrix TODO: Examples,Properties
Image RxTx Flasher TODO: Examples
Outputs
Image 7 Segment Quad
Image 7 Segment Single TODO: Examples
Image GLCD base TODO: Examples
Image LCD TODO: Examples,DLMacros,Properties
Image LCD Adafruit OLED TODO: Examples,DLMacros,Properties
Image LED Array
Image LED Base
Image LED Matrix (Parallel)
Image LED Matrix (Serial)
Image PWM
Image RAM LCD TODO: Examples,DLMacros,Properties
Image RGB LED
Image Speech TODO: Examples,Properties
Image Animator TODO: Examples
Image Data Injector
Image K8055D TODO: Examples
Image Meter Square TODO: Examples
Image PS2000 TODO: Examples,SimMacros
Image Sim. Switch Base TODO: Examples,SimMacros
Inputs
Image ADC base
Image Collision Detector TODO: Examples,Properties
Image Keypad Base
Image Proximity switch base TODO: Examples,Properties
Image Switch Array TODO: Examples
Image Switch base TODO: Examples
CAL
Image ADC TODO: Desc,Examples,SimMacros,Properties
Image CAN TODO: Examples,SimMacros,Properties
Image CAPTOUCH TODO: Desc,Examples
Image EEPROM TODO: Desc,Examples,Properties
Image I2C TODO: Examples,Properties
Image PWM TODO: Desc,Examples,Properties
Image SPI TODO: Desc,Examples,SimMacros,Properties
Image UART TODO: Desc,Examples,SimMacros,Properties
Misc
Image Bezel Radiused TODO: Examples
Image LCD control TODO: Examples,SimMacros,Properties
Image Square wave TODO: Examples,Properties
Image Target Chip TODO: Examples,Properties
Mechatronics
Image 3D Printer TODO: SimMacros,Properties
Image Accelerometer Compass EBM015 TODO: Examples,DLMacros,Properties
Image Accelerometer EB068 TODO: Examples,DLMacros,Properties
Image Accelerometer Gyro MPU_6050 TODO: Examples,Properties
Image Formula Flowcode TODO: Desc,Examples,Properties
Image Motor Base TODO: Examples,Properties
Image Photo Reflector TODO: Examples,DLMacros
Image Photo Transistor TODO: Examples,DLMacros
Image Quad Encoder TODO: Examples,Properties
Image Servo Controller TODO: Examples
Image Servo Motor Base TODO: Examples
Image Solenoid Base TODO: Examples
Image Stepper motor base TODO: Examples
DSP
Image Control TODO: Examples
Image DSP System TODO: Examples,Properties
Image Delay TODO: Examples
Image FFT Inverse TODO: Examples,DLMacros,Properties
Image Fast Fourier Transform (FFT) TODO: Examples,DLMacros,Properties
Image Filter TODO: Examples,Properties
Image Frequency Generator TODO: Examples
Image Input TODO: Examples
Image Kalman Filter TODO: Examples,DLMacros,Properties
Image Level TODO: Examples
Image Output TODO: Examples
Image Scale TODO: Examples
Image Sum TODO: Examples
Storage
Image EEPROM TODO: Examples
Image FAT
Image Lookup tables TODO: Examples
