Components
Revision as of 11:11, 16 January 2014 by JonnyW (talk | contribs) (XML import)
MIAC Module
Image MIAC TODO: Examples,SimMacros
Image MIAC USB Slave TODO: Desc
Controls
Image Dashboard Text TODO: Desc,Examples,SimMacros,Properties
Image Panel Console Viewer TODO: Examples,Properties
Image Scale Arc TODO: Examples
Image Scale_Linear TODO: Examples,Properties
Image Simulation LED TODO: Examples,Properties
Image Slider control TODO: Examples,SimMacros
Comms
Image CAN (Internal, MCP2515) TODO: Examples,SimMacros
Image I2C Master - Image LIN Master TODO: Examples,Properties
Image LIN Slave TODO: Examples,Properties
Image MIDI TODO: Examples,DLMacros,Properties
Image Modbus Master - Image One Wire TODO: Examples,DLMacros,Properties
Image RS232 - Image SPI Master TODO: Examples,DLMacros,Properties
Image TCP Base TODO: Examples,Properties
Image USB HID TODO: Examples
Image USB Serial TODO: Examples
Image USB Slave TODO: Examples
Image Visi (4DSystems) TODO: Examples
Image Webserver (EB023_00_1, NM7010A) TODO: Examples,DLMacros,Properties
Image Webserver (EB023_00_2, WIZ810MJ) TODO: Examples,DLMacros,Properties
Wireless
Image Bluetooth (EB024, Generic AT) TODO: Examples,Properties
Image GPS (EB056, Generic NMEA) TODO: Examples,Properties
Image GSM (EB066, Generic AT) TODO: Examples,DLMacros,Properties
Image IrDA (EB012, MCP1250, MCP2120) TODO: Examples,DLMacros,Properties
Image RC5 (EB060, Generic 36KHz) TODO: Examples,DLMacros,Properties
Image RF ISM (EB063, MRF49XA) TODO: Examples,Properties
Image RFID (EB052, RWD_MICODE) TODO: Examples,DLMacros,Properties
Image WLAN (EB069, WIZ610wi) TODO: Examples,Properties
Image Zigbee (EB051, XBEE) TODO: Examples,DLMacros,Properties
Advanced
Image Button helper TODO: Examples,Properties
Image COM Port TODO: Examples
Image Circular Buffer - Image Clone Matrix TODO: Examples
Image E_block Helper - Image FCD helper TODO: Examples
Image LCD control TODO: Examples,SimMacros,Properties
Image Marking control TODO: Examples,SimMacros
Image Motion Helper TODO: Examples
Image Port Matrix TODO: Examples,Properties
Image RxTx Flasher TODO: Examples
Outputs
Image 7Segment (Quad) TODO: Examples
Image 7Segment (Single) TODO: Examples
Image GLCD base TODO: Examples
Image LCD (Adafruit, OLED) TODO: Examples
Image LCD (Generic) TODO: Examples
Image LED (Generic, RGB) TODO: Examples
Image LED Array - Image LED Base - Image LED Matrix (Parallel) - Image LED Matrix (Serial) - Image PWM - Image RAM LCD TODO: Examples,DLMacros,Properties
Image Speech TODO: Properties
Image Animator TODO: Examples
Image Component Label TODO: Examples
Image Component Labels TODO: Examples
Image Data Injector - Image FTDI (FTD2XX) TODO: Examples
Image K8055D TODO: Examples
Image Meter Square TODO: Examples
Image PS2000 TODO: Examples,SimMacros
Image Sim. Switch Base TODO: Examples,SimMacros
Inputs
Image ADC base - Image Collision Detector TODO: Examples,Properties
Image Keypad (Generic) TODO: Examples
Image Proximity switch base TODO: Examples,Properties
Image Switch Array TODO: Examples
Image Switch base }
CAL
Image ADC TODO: Examples,SimMacros,Properties
Image CAN TODO: Examples,SimMacros,Properties
Image CAPTOUCH TODO: Examples
Image EEPROM TODO: Examples,Properties
Image I2C TODO: Examples,Properties
Image PWM TODO: Examples,Properties
Image SPI TODO: Examples,SimMacros,Properties
Image UART TODO: Examples,SimMacros,Properties
Misc
Image Bezel Radiused TODO: Examples
Image Target Chip TODO: Examples,Properties
Mechatronics
Image 3D Printer TODO: SimMacros,Properties
Image Accelerometer (EB068, LIS3LV02DQ) TODO: Examples,DLMacros,Properties
Image Accelerometer Compass (EBM015, LSM303DLHC) TODO: Examples,DLMacros,Properties
Image Accelerometer Gyro (MPU_6050) TODO: Examples,Properties
Image Formula Flowcode - Image Motor Base TODO: Examples,Properties
Image Photo Reflector - Image Photo Transistor - Image Quad Encoder - Image Servo Controller TODO: Examples
Image Servo Motor Base TODO: Examples
Image Solenoid Base TODO: Examples
Image Stepper motor base TODO: Examples
DSP
Image Control - Image DSP System - Image Delay - Image FFT Inverse TODO: Examples,DLMacros,Properties
Image Fast Fourier Transform (FFT) TODO: Examples,DLMacros,Properties
Image Filter - Image Frequency Generator - Image Input - Image Kalman Filter TODO: Examples,DLMacros,Properties
Image Level - Image Output - Image Scale - Image Sum }
Storage
Image EEPROM - Image FAT (SD, SDHC) TODO: Examples
Image Lookup tables }
