Components
Jump to navigationJump to search| TODO: Examples,SimMacros | |
| TODO: Desc |
| TODO: Desc,Examples,SimMacros,Properties | |
| TODO: Examples,Properties | |
| TODO: Examples | |
| Generic Two Wire I2C Communications Interface | |
| TODO: Examples,DLMacros,Properties | |
| Modbus component for talking to Modbus compatible hardware via RS232 or RS485. | |
| Low level routines for controlling or interacting with a standard asyncronous serial interface. | |
| TODO: Examples | |
| TODO: Examples | |
| TODO: Examples | |
| TODO: Examples | |
| TODO: Examples | |
| Circular buffer component allowing easy and efficient FIFO style data byte storage. | |
| TODO: Examples | |
| A purely cosmetic component to help simplify E-block connections without having to keep referring to the datasheets. | |
| TODO: Examples | |
| TODO: Examples,SimMacros,Properties | |
| TODO: Examples | |
| TODO: Examples |
| TODO: Examples | |
| TODO: Examples | |
| TODO: Examples | |
| TODO: Examples | |
| TODO: Examples | |
| TODO: Examples | |
| Create an evenly spaced array of LED indicators. | |
| Base for creating LEDs and other on/off visual indicators. | |
| LED Matrix component designed to work using multiple data pins and a single clock pin. | |
| LED Matrix component designed to work using a single data and clock pin. | |
| Pulse Width Modulation, a versitile way of generating a digital pulse using mark / space modulation. | |
| TODO: Properties |
| TODO: Examples | |
| TODO: Examples | |
| TODO: Examples | |
| A base data injector used as a placeholder in components which reference the data injector interface. | |
| TODO: Examples | |
| TODO: Examples | |
| TODO: Examples | |
| Base ADC component with no graphical interface. | |
| TODO: Examples | |
| TODO: Examples | |
| Base single pin switch with no graphical interface |
| TODO: Examples | |
| TODO: Examples | |
| TODO: SimMacros,Properties | |
| A component to allow all the features of the Formula Flowcode robot to be investigated. | |
| Uses InfraRed light to detect if an external object is near to the sensor. | |
| Quad encoder component implements a rotary encoder connected to two pins | |
| TODO: Examples | |
| TODO: Examples | |
| TODO: Examples | |
| TODO: Examples |
| Allows for several types of control operations to be performed on a buffer. | |
| DSP System main buffer manager responsible for allocating memory, taking care of buffer indexes ... | |
| Allows an adjustable delay to be inserted into the DSP system | |
| Filter component to allow basic filtering to be performed | |
| A frequency generator component designed to plug into the DSP system component and allow several... | |
| Allows the values from a buffer to be assigned. | |
| Allows for detection and collection of peaks, troughs and averages. | |
| Allows the values from a buffer to be read. | |
| Allows the values in a single buffer to be scaled uniformly. | |
| Component to combine together two buffers into one a index at a time. |
| A means of reading data from and writing data to the EEPROM memory onboard the microcontroller. | |
| TODO: Examples | |
| A lookup-table component allowing an easy way to place arrays of static data into ROM memory. |
