Components
| MIAC - Matrix Industrial Automotive Controller | |
| An easy way to display the data from up to four console windows on the panel. | |
| A base for drawing scales on a dial or circular meter | |
| A base control for drawing scales on horizontal or vertical strips | |
| A simple LED suitable for simulation that reflects the value of a pin | |
| A simple slider control with divides and interaction |
| Low level routines for controling the CAN interface either using an external MCP2515 IC and a SPI bus connection | |
| Generic Two Wire I2C Communications Interface | |
| Low level routines for controlling the LIN master interface. | |
| Low level routines for controlling the LIN slave interface. | |
| Low level routines for controlling or interacting with a MIDI interface. | |
| Modbus component for talking to Modbus compatible hardware via RS232 or RS485. | |
| Low level routines for controlling or interacting with a standard one wire interface. | |
| Low level routines for controlling or interacting with a standard asyncronous serial interface. | |
| Low level routines for controlling or interacting with an SPI interface. | |
| Base TCP/IP component with simulation only interface to allow TCP/IP style network communications in simulation. | |
| Component to create and communicate using a standard HID type USB class. | |
| Component to create and communicate using a standard CDC type COM port. | |
| Component to create and communicate using a generic USB communications profile. | |
| A way of interacting with the VISI interface designed by 4D systems. | |
| Webserver component designed to work with the WIZ3100 range of modules from Wiznet. | |
| Webserver component designed to work with the WIZ5100 range of modules from Wiznet. |
| Low level routines for controlling a standard AT Bluetooth interface. | |
| Component designed to process incoming NMEA style GPS data and convert into meaningful | |
| Low level routines for controlling a standard AT GSM / GPRS interface | |
| Low level routines for controlling a standard IrDA interface. | |
| Low level routines for controlling a standard RC5 IR interface. | |
| A simple RF-ISM communications module based on the Microchip Alpha MRF49XA device. | |
| Low level routines for controlling a RF Solutions RFID interface | |
| Wireless LAN component designed to work with the WIZ610wi module from Wiznet. | |
| Zigbee component designed to work with the XBEE range of modules from Digi. |
| A button overlay that allows any object to behave like a button | |
| Serial based simulation component for use with systems such as RS232, Bluetooth and USB Serial. | |
| Circular buffer component allowing easy and efficient FIFO style data byte storage. | |
| Takes a single object and produces an array of clones. | |
| A purely cosmetic component to help simplify E-block connections without having to keep referring to the datasheets. | |
| A helper control to query the current FCD file | |
| An LCD control pane supporting up to 64 x 64 units | |
| A control to draw markings on any component | |
| Helper for building components which require simulation of constant motion. | |
| Create an accuractely spaced array of up to eight components, each corresponding to a pin | |
| Simple indicator panel for your dashboard. |
| 14mm seven segment display. | |
| Seven segment display modelled after a standard 14mm high unit. | |
| Base graphical LCD with simulation only interface to allow graphics to be drawn in simulation. | |
| Adafruit OLED LCD display | |
| Generic configurable alphanumeric LCD display component based on the standard Hitachi HD44780 controller IC. | |
| An LED with red, green and blue elements that can be mixed together to produce | |
| Create an evenly spaced array of LED indicators. | |
| Base for creating LEDs and other on/off visual indicators. | |
| LED Matrix component designed to work using multiple data pins and a single clock pin. | |
| LED Matrix component designed to work using a single data and clock pin. | |
| Pulse Width Modulation, a versitile way of generating a digital pulse using mark / space modulation. | |
| A RAM-buffer for monitoring LCD changes | |
| Speech component allowing Phoneme based speech for use on an embedded platform. |
| Module for animating other objects. | |
| Generates a label for a component. | |
| Automatically generates labels for all panel objects and components. | |
| A base data injector used as a placeholder in components which reference the data injector interface. | |
| Simulation only interface to allow communications with a FTDI USB 232 IC connected to the system. | |
| Support for the Velleman K8055 USB input/output board. | |
| Square analogue panel meter as used in Locktronics. | |
| A set of functions designed for interacting with a 2000 series Pico scope via simulation. | |
| A base for building switches that do not download to chip. |
| Base ADC component with no graphical interface. | |
| Polls a chosen panel object to see if it has collided with another object. | |
| Generic component to create a raster scanned custom keypad or button matrix. | |
| Polls a chosen panel object to test it's distance from the component. | |
| Create an evenly spaced array of switches. | |
| Base single pin switch with no graphical interface |
| A low level implementation giving direct access to the CAL | |
| Low level routines for controling the CAN interface | |
| Chip Abstraction Layer for Two Wire I2C Communications | |
| A purely cosmetic component for creating smoothly radiused bezel or frame to fit around | |
| A cosmetic only representation of the target microcontoller device showing the default package type complete with pins. |
| A simulation only version of a very basic 3D printer such as a standard RepRap. | |
| LIS3LV02DQ Accelerometer sensor with options for I2C or SPI communications. | |
| LSM303DLHC Combined 6-Axis Accelerometer and Magnetometer sensors | |
| MPU-6050 Combined 6-Axis Accelerometer and Gyroscope sensors. | |
| A component to allow all the features of the Formula Flowcode robot to be investigated. | |
| Base component for constructing continuous motion - e. | |
| Uses InfraRed light to detect if an external object is near to the sensor. | |
| Quad encoder component implements a rotary encoder connected to two pins | |
| Can control up to eight standard PWM driven servo's. | |
| Base component for creating custom servo motor simulations. | |
| Base component for constructing solenoids. | |
| Enables the creation of a stepper motor component by specifying objects for its appearance. |
| Allows for several types of control operations to be performed on a buffer. | |
| DSP System main buffer manager responsible for allocating memory, taking care of buffer indexes ... | |
| Allows an adjustable delay to be inserted into the DSP system | |
| Provides functionality to convert frequency domain data into time domain data. | |
| Provides a way of converting a buffer full of time domain data into frequency domain data. | |
| Filter component to allow basic filtering to be performed | |
| A frequency generator component designed to plug into the DSP system component and allow several... | |
| Allows the values from a buffer to be assigned. | |
| Provides a way of intelligently filtering noise from data to allow for better sensor approximations. | |
| Allows for detection and collection of peaks, troughs and averages. | |
| Allows the values from a buffer to be read. | |
| Allows the values in a single buffer to be scaled uniformly. | |
| Component to combine together two buffers into one a index at a time. |
| A means of reading data from and writing data to the EEPROM memory onboard the microcontroller. | |
| FAT component allowing access to read and write files on a SD, SDHC or MMC card. | |
| A lookup-table component allowing an easy way to place arrays of static data into ROM memory. |
