ADC (AD7680)
16-bit external ADC connected to the microcontroller using SPI.
ADC Template
ADC (Analogue to Digital Converter) based components.
Encoder Rotary
Encoder component implements a rotary encoder connected to two pins
Keypad
Keypad (Generic)
Generic component to create a raster scanned custom keypad or button matrix.
Outputs
Outputs: General
Buzzer
Drives a simple fixed frequency buzzer in hardware and simulates the sound of a buzzer in simulation.
DAC Output
CAL = Code Abstraction Layer - Allows one code base to run on a wide range of chips.
PWM
Pulse Width Modulation, a versitile way of generating a digital pulse using mark / space modulation.
Piezo Sounder
Drives a simple variable frequency piezo sounder in hardware and simulates the sound in simulation.
Speech
Speech component allowing Phoneme based speech for use on an embedded platform.
Outputs: LEDs
Displays
Displays: Alphanumeric
Displays: Graphical
Bitmap Drawer FAT
A component to simplify the process of drawing bitmap images to a graphical display.
Bitmap Drawer ROM
GLCD Base
Base graphical LCD with simulation only interface to allow graphics to be drawn in simulation.
GLCD Graph Creator
A component to simplify the process of drawing graphs and charts using a graphical LCD.
GLCD Textfield
A component to simplify the process of drawing text to a graphical display.
Touch Screen (XPT2046)
Low level routines for controlling or interacting with the XPT2046 touch screen controller IC found
Displays: Segment
Sensors
Sensors
Grove
E-blocks
E-blocks 1
Accelerometer (EB068)
LIS3LV02DQ Accelerometer sensor with options for I2C or SPI communications.
Combo Board (EB083)
A simulated version of the EB083 Combo board including LEDs, Switches, LCD, 7-Segs
GLCD (EB057 / EB058)
Graphical display component designed to work with the EB057 modules and EB058 E-blocks.
Keypad (EB014)
Preset keypad based around the 3 * 4 unit, as used by the Matrix EB014 E-block
LCD (EB005)
LCD based on the unit used in the Matrix EB005 E-block
LED (EB004)
An LED matrix made up of standard PCB mount 5mm LEDs.
SPI Master (EB013)
Low level routines for controlling or interacting with an SPI interface.
Switch (EB007)
An array of up to eight momentary push switches, each connected to a single pin of the specified port.
TCPIP (EB023 v1)
TCP/IP component designed to work with the WIZ3100 range of modules from Wiznet.
TCPIP (EB023 v2)
TCP/IP component designed to work with the WIZ810MJ module from Wiznet,
Webserver (EB023 v1)
Webserver component designed to work with the NM7010A module from Wiznet,
Webserver (EB023 v2)
Webserver component designed to work with the WIZ810MJ module from Wiznet,
E-blocks 2
Bluetooth (BL0170)
Low level routines for controlling a Microchip RN4677 Bluetooth Module.
Colour GLCD (BL0157)
Graphical display component designed to work with the BL0157 E-block.Based on the ILI9163C 16-bit colour graphical controller IC.
Combo (BL0114)
A component to drive the BL0114 Combo board including LEDs, Switches, LCD, 7-Segs
GLCD (BL0139)
Graphical display component designed to work with the ST7567 type monochrome displays.
IO Expander (BL0155)
Provides 16 digital input/output pins arranged into two 8-bit E-block 2 ports using a SPI bus connection.
LCD (BL0169)
LCD component to drive the E-blocks 2 BL0169 LCD board.
LED (BL0167)
LED component to drive the E-blocks 2 BL0167 LED board.
Servo Motor (BL0162)
Servo motor component to drive the E-blocks 2 BL0162 Servo Motors board.
Switch (BL0145)
A set of 8 push switches that can be connected to an E-blocks 2 upstream board via a port connector.Switches are wired in an active high configuration.
WIFI (BL0136)
Wireless LAN component designed to work with the ESP-12S module.
EBM Modules
Comms
Comms: Interface
CAN (Internal, MCP2515)
Routines for controling the CAN interface either using an external MCP2515 IC and a SPI bus connection
FTDI (FTD2XX)
Simulation only interface to allow communications with a FTDI USB 232 IC connected to the system.
I2C Master
Routines for controlling an I²C Master interface.
I2C Slave
Routines for controlling an I²C Slave interface.
One Wire
Routines for controlling or interacting with a standard one wire interface.
SPI Master
Routines for controlling an SPI Master interface.
SPI Slave
Routines for controlling an SPI Slave interface.
UART (RS232)
Routines for controlling or interacting with a standard asynchronous serial interface.
Comms: Networking
Base 64
Component to allow base 64 encoding and decoding.
Network Communications
A component designed to simplify the process of TCP/IP communications.
TCP Template
Base TCP/IP component with simulation only interface to allow TCP/IP style network communications in simulation.
TCPIP (ENC28J60)
A set of routines used to control a ENC28J60 TCP/IP Module.
TCPIP (NM7010A)
TCPIP (Raspberry Pi)
TCP/IP sockets component for use with Raspberry Pi.
TCPIP (WIZ810MJ)
Webserver (NM7010A) (NM7010A)
Webserver (WIZ810MJ)
Comms: System
DALI Master
A serial based communications protocol designed for controlling lighting, specifically digitally
DALI Slave
DMX_512 Master
A serial based communications protocol designed for controlling theatrical equipment such
DMX_512 Slave
IO Expander (MCP23017)
Provides 16 digital input/output pins arranged into two 8-bit ports using a I2C bus connection.
IO Expander (MCP23S17)
Provides 16 digital input/output pins arranged into two 8-bit ports using a SPI bus connection.
IO Expander (PCF8574)
Provides 8 digital input/output pins arranged into an 8-bit port using a I2C bus connection.
IO Expander (PCF8575)
Provides 16 digital input/output pins arranged into 8-bit ports using a I2C bus connection.
MIDI
Low level routines for controlling or interacting with a standard MIDI interface.
MULTIUART (SPI2UART)
Uses a high speed SPI connection to enable up to four buffered external UARTs via the MULTIUART modules.
Modbus Master
Modbus component for talking to Modbus compatible hardware via RS232 or RS485.
Modbus Slave
Modbus component for creating Modbus compatible slave hardware via RS232 or RS485.
Modbus TCP Master
Modbus component for talking to Modbus compatible hardware via Ethernet or WIFI.
Modbus TCP Slave
Modbus component for creating Modbus compatible slave hardware via Ethernet or WIFI.
Visi (4DSystems)
A way of interacting with the VISI interface designed by 4D systems.
Comms: USB
USB HID
Component to create and communicate using a standard HID type USB class.
USB MIDI
Component to create and communicate using a standard MIDI connection.
USB Serial
Component to create and communicate using a standard CDC type COM port.
USB Slave
Component to create and communicate using a generic USB communications profile.
Injectors
Data Injector Template
Data injectors are used as a means to allow comms type components to have a meaningful simulation. Comms data is transferred via the injector component allowing for logging, connection to real world hardware and Flowcode to Flowcode type network communications.
Wireless
Bluetooth (EB024, Generic AT)
Low level routines for controlling a standard AT Bluetooth interface.
Bluetooth (HC05 HC06)
Low level routines for controlling or interacting with a HC05 or HC06 Bluetooth module.
Bluetooth (RN4677)
Bluetooth v2 (EB024, Generic AT)
GPS (EB056, Generic NMEA)
Component designed to process incoming NMEA style GPS data and convert into meaningful
GSM (EB066, Generic AT)
Low level routines for controlling a standard AT GSM / GPRS interface
IrDA (EB012, MCP1250, MCP2120)
Low level routines for controlling a standard IrDA interface.
RC5 (EB060, Generic 36KHz)
Low level routines for controlling a standard RC5 IR interface.
RF 2.4GHz (nRF24L01)
A simple RF communications module based on the 2.
RF ISM (EB063, MRF49XA)
A simple RF-ISM communications module based on the Microchip Alpha MRF49XA device.
RFID (EB052, RWD_MICODE)
Low level routines for controlling a RF Solutions RFID interface
RFID (MFRC522)
Functions designed to work with the MFRC522 contactless reader IC.
SRF (WirelessThings) (SRF)
The SRF is designed for wireless transmission and reception of serial data in an easy to use surface mounted module.
WLAN (ESP-12S)
WLAN (EB069, ESP8266) (ESP8266)
Wireless LAN component designed to work with the ESP8266 module.
WLAN (EB069, WIZ610wi)
Wireless LAN component designed to work with the WIZ610wi module from Wiznet.
Zigbee (EB051, XBEE) (XBEE)
Zigbee component designed to work with the XBEE range of modules from Digi.
Storage
Auto Version Identifier
Basic component designed to provide the program with the date and time of the build.
Circular Buffer
Circular buffer component allowing easy and efficient first in first out (FIFO) style data byte storage.
EEPROM
A means of reading data from and writing data to the EEPROM memory onboard the microcontroller.
Embed File
A component to simplify the process of embedding files into ROM.
FAT (SD, SDHC)
FAT component allowing access to read and write files on a SD, SDHC or MMC card.
Lookup tables
A lookup-table component allowing an easy way to place arrays of static data into ROM memory.
RTC (MCP7940N)
Serial (I2C) Real Time Clock component for MCP7940N device.
Real Time Clock (RTC)
A Real Time Clock component allowing things like clocks and timers to easily be created.
Serial EEPROM (24C16)
Serial (I2C) EEPROM component for 24C01 to 24C16
Serial EEPROM (24C32)
Serial (I2C) EEPROM component for 24C32
String Translator
A simple component to allow multiple language support by substituting different strings depending
Timer
Allows you to measure the passage of time via the use of a hardware timer peripheral.
WAV Library FAT
Contains component macros to allow playback and recording of WAV files via an SD card.
Mechatronics
Shield
Raspberry Pi
Sense Hat
A component to drive various features on the Raspberry Pi Sense Hat. Supported Features: 8x8 RGB LED / 5-Way Joystick.
MIAC
MIAC Module
MIAC: Addon Modules
MIAC: PC Peripheral
DSP
Control
Allows for several types of control operations to be performed on a buffer.
DSP System
DSP System main buffer manager responsible for allocating memory, taking care of buffer indexes ...
Delay
Allows an adjustable delay to be inserted into the DSP system
Fast Fourier Transform (FFT)
Provides a way of converting a buffer full of time domain data into frequency domain data.
Filter
Filter component to allow basic filtering to be performed
Frequency Generator
A frequency generator component designed to plug into the DSP system component and allow several...
Input
Allows the values from a buffer to be assigned.
Level
Allows for detection and collection of peaks, troughs and averages.
Output
Allows the values from a buffer to be read.
Scale
Allows the values in a single buffer to be scaled uniformly.
Sum
Component to combine together two DSP buffers into one an index at a time.
SCADA
Controls
Control Knob
Rotary control designed for SCADA.Has customisable value markings around the control.Simulation only.
Joystick
A simple joystick component allowing for easy mouse or touchscreen based analogue control.
Simulation Switch Template
A base for building switches that do not download to chip.Mouse interaction can send 'System.User' events with the following data...ID = The handle of the switch component sending the messageMessage = 1 (on) or 0 (off)Current state can also be read via simulation macros.
Indicators
Graph Plotter
A simple component to allow a number of values to be plotted onto a panel primitive.
Indicator Gauge
Simulation only round gauge/dial for SCADA applications. The range of values displayed is easily adjusted.
Indicator Meter
Square analogue panel meter.A simulation only component - the needle value is set solely by the 'SetValue' macro.
Logo Indicator
A simple component to display multiple icons relating to the state of a machine or process.Includes icons such as: tick, cross, alert, stop, go and coloured lights.
Numeric Display
Allows a numeric value to be displayed on the user panel using virtual 7 seg displays.Used for displaying the value of a variable during simulation runtime.Provides up to 5 customisable ranges to automatically alter the colour of the label based on the value.
Numeric Label
Allows a numeric label to be displayed on the user panel.Used for displaying the value of a variable during simulation runtime.Provides up to 5 customisable ranges to automatically alter the colour of the label based on the value.
Real Speak
Advanced speech engine allowing realistic text to speech in multiple languages using the RealSpeak voice engine.
Simulation LED Template
Base for creating simulation LEDs and other on/off visual indicators.Choose a 'Target Object' that will change colour when the pin changes;if multiple objects must change color, group them, and target the group.When 'Auto off color" is selected, changing the 'on color' will automaticallychoose an off color by reducing the intensity of the on color.
String Label
Industrial
Digital Valve
A simple digital valve that can be either open or closed. The valve has component macros to set and get the current state of the valve.The valve can be initialised to be open or closed when starting.The valve can be clicked to open or close via the runtime.Compatible with SCADA interconnecting pipe components.
Fan Pump
A simple rotating fan or pump.The component has macros to set and get the current rotational speed.Compatible with SCADA interconnecting pipe components.
Hopper
A simple hopper that can be used to store produce.The hopper has component macros to set and get the current level of produce.The hopper can be initialised to be full or empty when starting.Compatible with SCADA interconnecting pipe components.
Pipe
A Pipe Component
Right Angle Pipe
A Right Angle Component For Connecting Pipes Around Corners
SCADA Slaves
SCADA (Arduino Uno)
Connects to an Arduino Uno running the SCADA Arduino Uno Firmware allowing the board to become a slave to the flowcode simulation runtime.
Supports: Digital IO / ADC / I2C / SPI / PWM.
SCADA (ECIO28P)
Connects to an ECIO28P running the SCADA ECIO28P Firmware allowing the board to become a slave to the flowcode simulation runtime.
Supports: Digital IO / ADC / I2C / SPI / PWM / UART.
SCADA (ECIO40P)
Connects to an ECIO40P running the SCADA ECIO40P Firmware allowing the board to become a slave to the flowcode simulation runtime.
Event Log
A simulation component designed to create a simple log record of events in your SCADA system.Logs to a file and / or to a console tab including optional automated time stamp.
Timed Event Trigger
Component that will check to see if a predetermined amount of time has passed.Useful for doing things on a regular basis, e.g. every minute or every hour.
Animation
Animator
Basic animation and physics simulation for a single object.
Motion Helper
Helper for building components which require simulation of constant motion.
Scenarios
Airplane Landing Gear
A simulation of an Airplane Landing Gear containing, switches, locking mechanisms and retracting landing gear.
CNC Machine
A CNC Machine that allows for simulation movement in the X, Y, Z directions and also providing access to the Drill.
Car Seat
An electric car seat chassis with a series of motors and sensors.
Pedestrian Crossing
A set of pedestrian crossing lights complete with manual light control, a simple state machine and an
Sheep Pen
A simple sheep pen simulation with two gates and two sensors.
Traffic Light 1_Way
A set of one way traffic lights complete with manual light control, a simple state machine and an
Traffic Light 2_Way
A set of two way traffic lights complete with manual light control, a simple state machine and an
COM Port
Serial based simulation component for use with systems such as RS232, Bluetooth and USB Serial.
Console Debugger (Raspberry Pi)
Component to allow printing debug messages to the Raspberry Pi Console.
Device Helper
A purely cosmetic component for viewing the details specific to your current selected target microcontroller.
E_block Helper
A purely cosmetic component to help simplify E-block connections without having to keep referring to the datasheets.
FCD helper
A helper control to query the current FCD file
IntOsc Helper
A component to help configure the speed of the internal oscillator.
Scope monitor
A component to allow data from analogue and digital pins to be displayed on the scope window.
Serial Monitor
Allows data from a COM port to be piped through to the console window for easy program status and debugging.
Modelling Components
Clone Matrix
Takes a single object and produces a three dimensional array of evenly spaced clones.
Peripheral CAL
ADC (CAL)
Low level component for dealing with hardware abstracted analogue to digital conversion (ADC) functionality.
CAN (CAL)
Low level component for dealing with hardware abstracted internal CAN functionality.
EEPROM (CAL)
Low level component for dealing with hardware abstracted EEPROM functionality.
HBRIDGE (CAL)
Low level component for dealing with hardware abstracted H-Bridge functionality.
I2C (CAL)
Low level component for dealing with hardware abstracted I2C functionality.
PWM (CAL)
Low level component for dealing with hardware abstracted Pulse Width Modulation (PWM) functionality.
SPI (CAL)
Low level component for dealing with hardware abstracted SPI functionality.
UART (CAL)
Low level component for dealing with hardware abstracted Serial UART functionality.
UART SCADA (CAL)
Low level implementation giving direct access to the COM port peripheral.
Shapes
2D Shapes
3D Shapes
Bowl
A basic bowl primitive shape.
Cone
A basic cone primitive shape.
Cuboid
A basic cuboid primitive shape.
Cylinder
A basic cylinder primitive shape.
Diamond
A basic diamond primitive shape.
Hemisphere
A basic hemisphere primitive shape.
Honeycomb
A basic honeycomb primitive shape.
Prism
A basic prism primitive shape.
Pyramid
A basic pyramid primitive shape.
Sphere
A basic sphere primitive shape.
Tube
A basic tube primitive shape.
Advanced Shapes
Bezel Radiused
A purely cosmetic component for creating smoothly radiused bezel or frame to fit around
Component Label
Add a label to a component by including this component as a sub-component.
Component Labels
Automatically generates labels for all panel objects and components in a given context.
Dashboard Text
A simulation only text box that can be used to display text and numbers.
Marking control
A control to draw markings on any component
Panel Console Viewer
An easy way to display the data from up to four console windows on the panel.
RxTx Flasher
Simple indicator panel intended as a sub-component of communications components.
Scale Arc Template
A base component for drawing circular dials.
Scale Linear Template
A base component for drawing scales on horizontal or vertical strips.
Slider control
A simple graphical interface for a vertical meter or slider control.
Target Chip
A cosmetic only representation of the target microcontoller device showing the default package type complete with pins.
Wood Fence
A simple wooden fence used to create simple walls and pens for simulations.
Wood Gate
A simple gate that can be opened and closed via simulation macros.
