Components
In Flowcode IDE, a component is a predefined module or building block that represents a physical or logical element, which can be added to your project to simplify the process of designing and simulating embedded systems. These components can range from hardware elements like sensors, actuators, and communication devices, to software elements like variables, timers, or logic gates.
Each component typically comes with its own properties, methods, and events, which allow users to configure and interact with the component in a graphical way. For example:
Hardware components: These include microcontrollers, LEDs, motors, displays, or communication interfaces like I2C, SPI, and UART. Software components: These are functional blocks such as delays, counters, or decision-making constructs like conditionals or loops. Flowcode simplifies embedded programming by allowing you to drag and drop these components into your design, and then connect and configure them without the need to write low-level code manually. However, it still offers the flexibility to add custom code when needed.
Each component can also be simulated, allowing you to test and debug your design before deploying it to the actual hardware.
Embedded Components
| General Input | ||
| Grey Code Encoder | 3d | |
| Grey Code Encoder 2D | 2d | |
| IO Expander (MCP23017) | 2d | |
| IO Expander (MCP23S17) | 2d | |
| IO Expander (PCF8574) | 2d | |
| IO Expander (PCF8575) | 2d | |
| Quadrature Encoder | 3d | |
| Quadrature Encoder | 2d | |
| Analog Input | ||
| ADC (AD7680) | 2d | |
| ADC (MCP356X) | 2d | |
| ADC 24bit ADS1220 | 2d | |
| ADC ADS1256 | 2d | |
| ADC QUAD + DAC (PCF8591) | 2d | |
| ADC Template | 2d | |
| ADC Template 2D | 2d | |
| ADC16bit ADS111x | 2d | |
| Joystick (Sparkfun Quiic) | 3d | |
| Joystick (Sparkfun Quiic) 2D | 2d | |
| Potentiometer | 2d | |
| Potentiometer (Slider) | 2d | |
| Switch | ||
| Rotary Switch | 3d | |
| Switch (Microswitch) | 3d | |
| Switch Push Button | 2d | |
| Switch Rotary 0 - 1 | 2d | |
| Switch Rotary 0 - 15 | 2d | |
| Switch Slide | 2d | |
| Switch User Images | 2d | |
| Switches | ||
| Switch Array (Push) | 3d | |
| Switch Array (Push) | 2d | |
| Switch Array (Slide) | 3d | |
| Switch Array (Slide) | 2d | |
| Keypad | ||
| Keypad | 2d | |
| Keypad (Cursor 3x3) | 2d | |
| Keypad (Hex 4x4) | 2d | |
| Graphical Library | ||
| Display Manager | 2d | |
| GLCD Bitmap Drawer FAT | 2d | |
| GLCD Bitmap Drawer ROM | 2d | |
| GLCD Graph Creator | 2d | |
| GLCD Graph Creator XY | 2d | |
| GLCD QR Code Generator | 2d | |
| GLCD Textfield | 2d | |
| Touch Screen (FT6X06) | 2d | |
| Touch Screen (GT911) | 2d | |
| Touch Screen (Resistive) | 2d | |
| Touch Screen (XPT2046) | 2d | |
| Graphical Manager Primitives | ||
| Bitmap | wysiwyg | |
| Ellipse | wysiwyg | |
| Hidden | wysiwyg | |
| Line | wysiwyg | |
| Rectangle | wysiwyg | |
| Rounded Rectangle | wysiwyg | |
| Slider | wysiwyg | |
| Text | wysiwyg | |
| Buffer | ||
| Circular Buffer (16-bit) | 2d | |
| Circular Buffer (8-bit) | 2d | |
| Circular Buffer (Float) | 2d | |
| EEPROM | ||
| EEPROM | 2d | |
| EEPROM (DS28E07) | 2d | |
| FRAM MB85RC | 2d | |
| Flash EEPROM | 2d | |
| IButton (DS1990) | 2d | |
| Serial EEPROM (24C01 - 24C16) | 2d | |
| Serial EEPROM (24C32) | 2d | |
| Serial EEPROM (24LC512) | 2d | |
| Serial EEPROM (93C46) | 2d | |
| Serial Flash (W25) | 2d | |
| File | ||
| CSV Read/Write | 2d | |
| Embed File | 2d | |
| File (ESP32 SDMode) | 2d | |
| File (RPI) | 2d | |
| File (SD/SDHC Card) | 2d | |
| Real Time Clock | ||
| Real Time Clock (ESP32) | 2d | |
| Real Time Clock (Internal, DS1307, DS3231, DS3232) | 2d | |
| Real Time Clock (MCP7940N) | 2d | |
| Real Time Clock (PCF8563) | 2d | |
| Utility | ||
| Advanced String Functions | 2d | |
| Auto Version Identifier | 2d | |
| Lookup tables | 2d | |
| String Initialiser | 2d | |
| String Translator | 2d | |
| Calculation | ||
| Base 64 | 2d | |
| CRC | 2d | |
| Linear Feedback Shift Register | 2d | |
| Map Function | 2d | |
| Median 16-bit | 2d | |
| Median 32-bit | 2d | |
| Median Float | 2d | |
| Modified Moving Average 16-bit | 2d | |
| Modified Moving Average 32-bit | 2d | |
| Modified Moving Average Float | 2d | |
| Running Average 16-bit | 2d | |
| Running Average Float | 2d | |
| Standard Deviation | 2d | |
| Type Conversions | 2d | |
| Timing | ||
| PIC32 Core Timer | 2d | |
| STM32 Timer | 2d | |
| Timed Interval | 2d | |
| Timer | 2d | |
| DSP Inputs | ||
| Data Queue to Bits | 2d | |
| Input ADC | 2d | |
| Input CSV | 2d | |
| Input Digital | 2d | |
| Input Digital Pin | 2d | |
| Quadrature Generator | 2d | |
| Waveform Generator | 2d | |
| DSP Outputs | ||
| Bits to Data Queue | 2d | |
| Level | 2d | |
| Output CSV | 2d | |
| Output DAC | 2d | |
| Output Digital | 2d | |
| Output Digital Pin | 2d | |
| Output PWM | 2d | |
| Output Port | 2d | |
| DSP Operators | ||
| Adder | 2d | |
| Averager | 2d | |
| Deinterlace | 2d | |
| Delay | 2d | |
| Fast Fourier Transform (FFT) | 2d | |
| Filter | 2d | |
| Interlace | 2d | |
| Kalman Filter | 2d | |
| Math | 2d | |
| Median | 2d | |
| Multiplex | 2d | |
| Offset | 2d | |
| On/Off Control | 2d | |
| PID Control | 2d | |
| Rectifier | 2d | |
| Scale | 2d | |
| Simulated Control Load | 2d | |
| API Slave Devices | ||
| API (Arduino Mega) | 2d | |
| API (Arduino Uno) | 2d | |
| API (BL0032) | 2d | |
| API (ECIO28P) | 2d | |
| API (ECIO40P) | 2d | |
| API (ESP32) | 2d | |
| API (Interface Board) | 2d | |
| API (RPI) | 2d | |
| Test Injectors | ||
| Injector (API Analog Input) | 2d | |
| Injector (API Digital Input) | 2d | |
| Injector (API Digital Output) | 2d | |
| Injector (AT) | 2d | |
| Injector (COM) | 2d | |
| Injector (File) | 2d | |
| Injector (Flowcode vNet) | 2d | |
| Injector (Human Interface) | 2d | |
| Scenarios | ||
| 3D Printer | 3d | |
| Airplane Landing Gear | 3d | |
| CNC Machine | 3d | |
| Car Seat | 3d | |
| Daytona Racetrack | 3d | |
| Maze Generator | 3d | |
| Oven Simulation | 2d | |
| Pedestrian Crossing | 3d | |
| Pedestrian Crossing | 2d | |
| Traffic Light | 2d | |
| Traffic Light 1-Way | 3d | |
| Traffic Light 2-Way | 3d | |
| Matrix Tools | ||
| Device Helper | 2d | |
| FCD helper | 2d | |
| IntOsc Helper | 2d | |
| Is Sim | 2d | |
| Indicators | ||
| Circular Gauge | 2d | |
| Console Writer | 2d | |
| LinearGauge | 2d | |
| Logo Indicator | 3d | |
| Numeric Display | 3d | |
| On / Off Indicator | 2d | |
| Speech (RealSpeak) | 2d | |
| Controls | ||
| Circular Knob | 2d | |
| Joystick | 3d | |
| Joystick 2D | 2d | |
| LinearSlider | 2d | |
| Number Pad | 2d | |
| RadioButton | 2d | |
| Charts | ||
| Area Chart | 2d | |
| Bar Chart | 2d | |
| Bubble Chart | 2d | |
| Column Chart | 2d | |
| Historic Chart | 2d | |
| Line Chart | 2d | |
| Pie Chart | 2d | |
| Polar Chart | 2d | |
| Radar Chart | 2d | |
| Ternary Chart | 2d | |
| XY Chart | 2d | |
| Runtime Tools | ||
| COM Port | 2d | |
| Console Debugger | 2d | |
| Console User Input | 2d | |
| Data Recorder Setup | 2d | |
| Event Log | 2d | |
| Input Message Box | 2d | |
| Keyboard | 2d | |
| Mouse | 2d | |
| Panel Console Viewer | 2d | |
| Property Manager | 2d | |
| Serial Monitor | 2d | |
| Simulation External Input | 2d | |
| Time Stamp | 2d | |
| Timed Event Trigger | 2d | |
| Tone Generator | 2d | |
| XML JSON Parser | 2d | |
| Primitives (2d) | ||
| Base Chart | 2d | |
| Button | 2d | |
| Canvas | 2d | |
| ComboBox | 2d | |
| Complex Shape | 2d | |
| Connection | 2d | |
| EditBox | 2d | |
| Gauge | 2d | |
| Grid | 2d | |
| Image | 2d | |
| Line | 2d | |
| Numeric Indicator | 2d | |
| RichText | 2d | |
| Shape | 2d | |
| Simple | 2d | |
| Switch | 2d | |
| Text | 2d | |
| Primitives (3d) | ||
| 3D Panel Measurement Tool | 3d | |
| Label | 3d | |
| Shape | 3d | |
| Text box | 3d | |
App Developer Components
| Digital Control | ||
| Keyboard | 2d | |
| Number Pad | 2d | |
| Analog Control | ||
| Joystick | 3d | |
| Mouse | 2d | |
| Dialogue Control | ||
| Digital Indicator | ||
| 7Segment (Single) | 2d | |
| LED Array | 2d | |
| LED Mono | 2d | |
| LED Mono Custom | 2d | |
| LED Mono User Images | 2d | |
| Analog Indicator | ||
| Dialogue Indicator | ||
| Audio Indicator | ||
| WAV Library File | 2d | |
| Area Chart | 2d |
| Bar Chart | 2d |
| Bubble Chart | 2d |
| Column Chart | 2d |
| Line Chart | 2d |
| Pie Chart | 2d |
| Polar Chart | 2d |
| Radar Chart | 2d |
| XY Chart | 2d |
| Buffer | ||
| File | ||
| Embed File | 2d | |
| Event Log | 2d | |
| File Access | 2d | |
| Utility | ||
| Calculation | ||
| Base 64 | 2d | |
| CRC | 2d | |
| Timing | ||
| Stopwatch | 2d | |
| Time Stamp | 2d | |
| Timer Interrupt | 2d | |
| DSP Inputs | ||
| Input CSV | 2d | |
| DSP Outputs | ||
| Level | 2d | |
| Output CSV | 2d | |
| DSP Operators | ||
| Adder | 2d | |
| Averager | 2d | |
| Delay | 2d | |
| Filter | 2d | |
| Interlace | 2d | |
| Math | 2d | |
| Median | 2d | |
| Multiplex | 2d | |
| Offset | 2d | |
| Rectifier | 2d | |
| Scale | 2d | |
| Comms: Interface | ||
| BLE GATT SPP | 2d | |
| COM Port | 2d | |
| I2C Multiplexer (TCA9548A) | 2d | |
| LIN Master | 2d | |
| Comms: System | ||
| J1939 Automotive Node | 2d | |
| Modbus Master (SCADA) | 2d | |
| Modbus Slave (SCADA) | 2d | |
| Modbus TCP Master | 2d | |
| Modbus TCP Slave | 2d | |
| OBD2 ECU (Server) | 2d | |
| Comms: IoT/Cloud | ||
| BBC News | 2d | |
| BBC Weather Forecast | 2d | |
| BBC Weather Observation | 2d | |
| IoT Made Easy | 2d | |
| JSON Decoder | 2d | |
| JSON Encoder | 2d | |
| MQTT Client | 2d | |
| Comms: Networking | ||
| Network Communications | 2d | |
| Webserver (GENERIC - Flash / File) | 2d | |
| E-blocks 3 | ||
| E-Blocks 3 (USB Comms) | 2d | |
| E-blocks 3 Sensors | ||
| Accel / Gyro / Mag 9-Axis (LSM9DS1 / BL0135) | 2d | |
| Temp / Humidity (SHT41 / BL0144) | 2d | |
| Thermocouple (MAX31855 / BL0126) | 2d | |
| E-blocks 2 Sensors | ||
| Accel / Gyro 6-Axis (Grove 105020012) | 2d | |
| Barometer (BMP280 / Grove 101020192) | 2d | |
| Colour Sensor (Grove 101020341) | 3d | |
| Colour Sensor V3 (Grove 101021133) | 3d | |
| Temp / Humidity (Grove 101020212) | 2d | |
| AllCode | ||
| Control | 2d | |
| Electrical Machines | 2d | |
| Formula AllCode API | 2d | |
| MIAC AllCode API (dsPIC) | 2d | |
| MIAC NXT AllCode API | 2d | |
| MIAC USB Slave API (PIC) | 2d | |
| Robot Arm v2 | 2d | |
| API (RPI) | 2d | |
| Test Equipment | ||
| PicoScope | 2d | |
| TTI Power Supply - PL155-P | 2d | |
| TTI TG5011 Signal Generator | 2d | |
| Third Party | ||
| FTDI (FTD2XX) | 2d | |
| Base Chart | 2d | |
| Button | 2d | |
| Canvas | 2d | |
| ComboBox | 2d | |
| Connection | 2d | |
| EditBox | 2d | |
| Gauge | 2d | |
| Grid | 2d | |
| Image | 2d | |
| Line | 2d | |
| RichText | 2d | |
| Shape | 2d | |
| Simple | 2d | |
| Switch | 2d | |
| Text | 2d | |
| Label | 3d | |
| Shape | 3d | |
| Text box | 3d | |
Web Developer Components
| Control | ||
| Button | 2d | |
| Check Box | 2d | |
| Choose Colour | 2d | |
| Choose File | 2d | |
| Combo Box | 2d | |
| Input Text | 2d | |
| Radio Button | 2d | |
| Slider | 2d | |
| Switch | 2d | |
| Area Chart | 2d |
| Bar Chart | 2d |
| Column Chart | 2d |
| Line Chart | 2d |
| Pie Chart | 2d |
| Comms | ||
| Bluetooth | 2d | |
| HTTP Fetch | 2d | |
| HTTP Params | 2d | |
| SerialPort | 2d | |
| Data | ||
| Array Helper | 2d | |
| Create File | 2d | |
| Location | 2d | |
| Object Helper | 2d | |
| Orientation | 2d | |
| Popup Message | 2d | |
| Speech | 2d | |
| Storage | 2d | |
| Timer | 2d | |
| Timestamp | 2d | |
| Vibrate | 2d | |
| Primitives | ||
| Base Chart | 2d | |
| Canvas | 2d | |
| Image | 2d | |
| Line | 2d | |
| RichText | 2d | |
| Shape | 2d | |
| Simple | 2d | |
| Text | 2d | |
| Web Primitives | ||
| Image | 2d | |
| ImageUrl | 2d | |
| Label | 2d | |
| Shape | 2d | |
| Text Block | 2d | |
| TextUrl | 2d | |
