Components
Revision as of 10:17, 27 April 2026 by SteveT (talk | contribs) (Removed hidden "WebDeveloper->Creation->Primitives" section)
In Flowcode IDE, a component is a predefined module or building block that represents a physical or logical element, which can be added to your project to simplify the process of designing and simulating embedded systems. These components can range from hardware elements like sensors, actuators, and communication devices, to software elements like variables, timers, or logic gates.
Each component typically comes with its own properties, methods, and events, which allow users to configure and interact with the component in a graphical way. For example:
Hardware components: These include microcontrollers, LEDs, motors, displays, or communication interfaces like I2C, SPI, and UART. Software components: These are functional blocks such as delays, counters, or decision-making constructs like conditionals or loops. Flowcode simplifies embedded programming by allowing you to drag and drop these components into your design, and then connect and configure them without the need to write low-level code manually. However, it still offers the flexibility to add custom code when needed.
Each component can also be simulated, allowing you to test and debug your design before deploying it to the actual hardware.
Embedded Components
Segment
4-Digit Display (Grove 104030003) 3d
4-Digit Display (Grove 104030003) 2D 2d
7Segment both
7Segment (74HC595) 3d
7Segment (74HC595) 2D 2d
7Segment (Hex TM1637) 3d
7Segment (Hex TM1637) 2D 2d
7Segment (Quad TM1637) 2d
7Segment (Quad) 3d
7Segment (Quad) 2D 2d
7Segment (Single) 3d
7Segment (Single) 2d
Starburst Display 3d
Starburst Display 2d
Alphanumeric
LCD (Adafruit, 16x2) 2d
LCD (Adafruit, 20x4) 2d
LCD (Generic, 16x2) 2d
LCD (Generic, 20x4) 2d
LCD (Generic, Configurable) 2d
LCD (Grove - I2C) 2d
LCD (Grove - UART) 2d
LCD (ST7032i) 2d
LCD I2C (Backpack) 2d
LCD I2C (LCM1602) 2d
LCD SPI (MiniClick) 2d
Graphical Color
GLCD (E-BLOCKS 3) 2d
GLCD (GC9A01A SPI) 2d
GLCD (ILI9163C) 2d
GLCD (ILI9341 SPI) 2d
GLCD (ILI9341) 2d
GLCD (ILI9488 SPI) 2d
GLCD (ILI9488) 2d
GLCD (LS020) 2d
GLCD (SSD1289) 2d
GLCD (SSD1331) 2d
GLCD (SSD1351 SPI) 2d
GLCD (SSD1351) 2d
GLCD (SSD1963) Parallel 2d
GLCD (ST7735) 2d
GLCD (ST7789V) 2d
GLCD (ST7796 SPI) 2d
GLCD (STM32F429ZI) 2d
GLCD (STM32F469NI) 2d
GLCD (STM32F746NG) 2d
Nextion Display 2d
Raspberry Pi HDMI 2d
Graphical Monochrome
GLCD (Grove OLED) 2d
GLCD (KS0108) 2d
GLCD (PDC8544) 2d
GLCD (SH1106) I2C 2d
GLCD (SH1106) SPI 2d
GLCD (SSD1305) 2d
GLCD (SSD1305) Buffered 2d
GLCD (SSD1305) I2C 2d
GLCD (SSD1306) 2d
GLCD (SSD1306) Buffered 2d
GLCD (SSD1306) I2C 2d
GLCD (SSD1322) Buffered 2d
GLCD (SSD1322) Parallel 2d
GLCD (SSD1327) I2C 2d
GLCD (SSD1327) SPI 2d
GLCD (ST7036) I2C 2d
GLCD (ST7565R) Parallel 2d
GLCD (ST7565R) SPI 2d
GLCD (ST7567) SPI 2d
GLCD (ST7567) SPI NOBUFF 2d
GLCD (ST7920) 2d
GLCD (T6963C) 2d
GLCD (TLS8201) 2d
GLCD (UC1701) 2d
GLCD eINK (IL3829) 2d
GLCD eINK (SSD1681) 2d
Audio
Heelight Sensor (Grove 101020312) 2d
Sound Sensor (Grove 101020023) 2d
Ultrasonic 2d
Ultrasonic Ranger (Grove 101020010) 2d
Electrical
Battery Cell Fuel Gauge (MAX17043 MAX17044) 2d
Current Sensor (ACS7xx) 2d
Current Sensor (ILA260) 2d
Energy Monitor (PZEM-004T) 2d
LTSR Current Transducer 2d
Environmental
Air Quality (BME688) 2d
Air Velocity Sensor (FS3000) 2d
Analogue Temp Sensors 2d
Barometer (BME280) 2d
Barometer (BMP180) 2d
Barometer (BMP280 / Grove 101020192) 2d
Barometer (DPS310) 2d
Barometer (MS5637) 2d
Humidity AHT10 2d
Magnetometer (BMM150) 2d
Pulse Oximeter (Max30100) 2d
RTD (MAX31865) 2d
Temp / Humidity (DHT11) 2d
Temp / Humidity (DHT22) 2d
Temp / Humidity (Grove 101020019) 2d
Temp / Humidity (Grove 101020212) 2d
Temp / Humidity (HTS221) 2d
Temp / Humidity (SHT21) 2d
Temp / Humidity (SHT31) 2d
Temp / Humidity (SHT41 / BL0144) 2d
Temperature (DS1822) 2d
Temperature (DS18B20) 2d
Temperature (DS18S20) 2d
Temperature (LM75B) 2d
Temperature (TMP117) 2d
Temperature Infrared (Grove 101020062) 2d
Temperature Sensor (Grove 101020015) 2d
Thermistor 2d
Thermistor Using Beta 2d
Thermocouple (MAX31855 / BL0126) 2d
Thermocouple (MAX31856) 2d
Thermocouple (MCP960X) 2d
Water Sensor (Grove 101020018) 2d
Force
Bridge Amplifier (HX711 / BL0122 / BL0132) 2d
Light
Ambient Light 2d
Beam Breaker 3d
Colour Sensor 3d
Colour Sensor (Grove 101020341) 3d
Colour Sensor V3 (Grove 101021133) 3d
Infrared Array AMG88xx 2d
Infrared Reflective Sensor (Grove 101020174) 3d
Light Sensor (Grove 101020132) 2d
PIR Motion (Grove 101020020) 2d
Photo Reflector 3d
Photo Reflector 2D 2d
Photo Transistor 3d
Photo Transistor 2D 2d
Range Time of Flight (VL53L0X) 2d
Magnetic
Hall Effect Analog 2d
Hall Effect Digital 3d
Magnetic Encoder (AS5600) 2d
Reed Switch 3d
Movement Orientation
Accel / Gyro / Mag 9-Axis (LSM9DS1 / BL0135) 2d
Accel / Gyro / Mag 9-Axis (MPU9250) 2d
Accel / Gyro 6-Axis (Grove 105020012) 2d
Accel / Gyro 6-Axis (MPU-6050) 2d
Accel / Gyro 6-Axis (MPU-6886) 2d
Accel / Mag 6-Axis (LSM303D) 2d
Accel / Mag 6-Axis (LSM303DLHC) 2d
Accelerometer 3-Axis (LIS3DHTR) 2d
Accelerometer 3-Axis (LIS3LV02DQ) 2d
Accelerometer 3-Axis (MMA8452Q) 2d
Gyroscope 3-Axis (L3G4200D) 2d
Gyroscope 3-Axis I2C (L3GD20) 2d
Gyroscope 3-Axis SPI (L3GD20) 2d
Magnetometer (SM324) 2d
Magnetometer 3-Axis (HMC5883L) 2d
Magnetometer 3-Axis (QMC5883L) 2d
Wii Nunchuk 2d
Comms: Interface
CAN (Internal, MCP2515) 2d
I2C Master 2d
I2C Multiplexer (TCA9548A) 2d
I2C Slave 2d
I2S Master/Slave ESP32 2d
LIN Master 2d
LIN Slave 2d
MULTIUART 2d
One Wire 2d
One Wire (DS2482) 2d
SPI Master 2d
SPI Slave 2d
UART (RS232) 2d
UART Software (Timer) 2d
Comms: System
DALI Master 2d
DALI Slave 2d
DMX-512 Master 2d
DMX-512 Slave 2d
J1939 Automotive Node 2d
MIDI 2d
Modbus Master 2d
Modbus Slave 2d
Modbus Slave USB 2d
Modbus TCP Master 2d
Modbus TCP Slave 2d
OBD2 ECU (Server) 2d
Visi (4DSystems) 2d
Comms: IoT/Cloud
BBC News 2d
BBC Weather Forecast 2d
BBC Weather Observation 2d
EtherCAT Slave (EasyCAT) 2d
IoT Made Easy 2d
JSON Decoder 2d
JSON Encoder 2d
LoRaWAN (Seeed WIO-E5) 2d
MQTT Client 2d
Comms: Networking
Hydro Encryption 2d
Network Communications 2d
TCP/IP (ENC28J60) 2d
TCP/IP (NM7010A) 2d
TCP/IP (Raspberry Pi) 2d
TCP/IP (W5500) 2d
TCP/IP (WIZ810MJ W5100) 2d
WLAN (E-Blocks 3) 2d
WLAN (ESP-12S) 2d
WLAN (ESP32) 2d
WLAN (ESP8266) 2d
Webserver (GENERIC - Flash / File) 2d
Webserver (NM7010A) 2d
Webserver (W5500) 2d
Webserver (WIZ810MJ) 2d
Comms: USB
USB HID 2d
USB MIDI 2d
USB Serial 2d
USB Slave 2d
Wireless
Bluetooth (E-Blocks 3) 2d
Bluetooth (EB024, Generic AT) 2d
Bluetooth (ESP32 SPP) 2d
Bluetooth (HC05 / HC06) 2d
Bluetooth (RN4677) 2d
Bluetooth BLE (ESP32 SPP Client) 2d
Bluetooth BLE (ESP32 SPP Server) 2d
Bluetooth v2 (EB024, Generic AT) 2d
GPS (EB056, Generic NMEA) 2d
GSM (EB066, Generic AT) 2d
IrDA (EB012, MCP1250, MCP2120) 2d
LoRa (LAMBDA SX1272) 2d
RC5 (EB060, Generic 36KHz) 2d
RF ISM (EB063, MRF49XA) 2d
RF Transceiver (nRF24L01) 2d
RFID (EB052, RWD-MICODE) 2d
RFID (MFRC522) 2d
RFID (Sparkfun Quiic / ID-12LA) 2d
SRF (WirelessThings) 2d
Zigbee (EB051, XBEE) 2d
Primitives (2d)
Button 2d
Canvas 2d
ComboBox 2d
Complex Shape 2d
Connection 2d
EditBox 2d
Gauge 2d
Image 2d
Line 2d
Numeric Indicator 2d
RichText 2d
Shape 2d
Switch 2d
Text 2d
Primitives (3d)
3D Panel Measurement Tool 3d
Label 3d
Shape 3d
Text box 3d
App Developer Components
API Audio
DFPlayer (MP3 / WAV) 2d
API Comms
E-Blocks 3 (USB Comms) 2d
I2C Master 2d
MULTIUART 2d
SPI Master 2d
UART (RS232) 2d
API Display
API Environmental
Humidity AHT10 2d
RTD (MAX31865) 2d
API Electrical
ADC ADS1256 2d
API IO
ADC (AD7680) 2d
ADC (MCP356X) 2d
ADC QUAD + DAC (PCF8591) 2d
DAC (AD5662) 2d
DAC (MCP4725) 2d
DAC (MCP47x6) 2d
DAC (MCP48x1) 2d
DAC (MCP49x1) 2d
DAC Dual (MCP48x2) 2d
DAC Dual (MCP49x2) 2d
DAC Quad (MCP4728) 2d
DDS DAC (AD9834/AD9833) 2d
Digital Potentiometer (AD528X) 2d
Digital Potentiometer (MCP41XX / MCP42XX) 2d
Digital Potentiometer (MCP41XXX / MCP42XXX) 2d
Digital Potentiometer (MCP44XX) 2d
Digital Potentiometer (MCP45XX / MCP46XX) 2d
Grove I2C Motor Driver 2d
IO Expander (MCP23017) 2d
IO Expander (MCP23S17) 2d
IO Expander (PCF8574) 2d
IO Expander (PCF8575) 2d
Joystick (Sparkfun Quiic) 3d
Joystick (Sparkfun Quiic) 2D 2d
PWM 16CH 12Bit (PCA9685) 2d
API Light
Ambient Light 2d
API Movement Orientation
Primitives (2d)
Button 2d
Canvas 2d
ComboBox 2d
Complex Shape 2d
Connection 2d
EditBox 2d
Gauge 2d
Image 2d
Line 2d
RichText 2d
Shape 2d
Switch 2d
Text 2d
Primitives (3d)
Label 3d
Shape 3d
Text box 3d
Web Developer Components
